WAC6503D-S power problem with Cisco Switch WS-C2960X-24PD-L [solved]
2»
  • Zyxel_Joslyn
    Zyxel_Joslyn Posts: 360
    25 Answers First Comment Friend Collector Fourth Anniversary
    image  Zyxel Employee
    edited March 2019
    Hi @norwegiansalmon,
    Do you only need the DF of WAC6303 or need another controller DF?
    Thanks.
    Joslyn
  • norwegiansalmon
    norwegiansalmon Posts: 2
    image  Freshman Member
    Thanks.
    Joslyn
    We are using a VPN100 as a controller for the WAC6303's and wish to continue doing so.
    I suppose I would just need the firmware for the WAC6303 so I can distribute and apply it through the VPN100 using the command "capwap firmware-update source DF-Firmware".
    The only problem we are experiencing is that the AP's only gets limited power and not Full.
  • Zyxel_Joslyn
    Already send you the DF link via the private message. Please check your inbox and let me know if it helps.
    Thanks.
    Joslyn
  • amra
    amra Posts: 1
    Network Detective-New Adventure Badge First Comment Sixth Anniversary
    Same problem with WAX510D with Cisco 2960X-48LPS-L (370w). 8 units deployed and appears with "limited power" in nebula power mode. Tryied to disable CDP and force ports to 30w consumption.
    Any solution for that?
  • Zyxel_Joslyn
    Hi @amra
    Can you help to check if there is an option as "LLDP-MED" on the Cisco switch? This option should be enabled to let the power negotiation smoothly. If possible, can you provide us your org/site name and enable ZYXEL support(HELP>Support request) for us? We will check the power mode.
    Joslyn
