NebulaFlex Switch GS2220 Series - V4.80 Patch 0 Firmware Release
Zyxel_Melen
Zyxel_Melen Posts: 5,145
image  Zyxel Employee
edited July 2024 in Switch New Release
Zyxel Switch GS2220 Series
Release Note
February 2023
Firmware Version on all models
Zyxel GS2220-10       - V4.80(ABRO.0)
Zyxel GS2220-10HP  - V4.80(ABRP.0)
Zyxel GS2220-28       - V4.80(ABRQ.0)
Zyxel GS2220-28HP  - V4.80(ABRR.0)
Zyxel GS2220-50       - V4.80(ABRS.0)
Zyxel GS2220-50HP  - V4.80(ABRT.0)
New Feature and Enhancements
CLD=Cloud mode, STD=Standalone mode
No.
CLD
STD
1.
Renovate Web GUI layout for better usability of Switch management.
V
V
2.
Intuitive Cloud connection status with help message.
3.
Strengthen security for network management with built-in notification in case of abnormal login attempt.
V
V
4.
Support logs to indicate the cause of CPU high.
V
V
5.
Log information for IP conflict between Switch and gateway both obtain the same IP address.
V
V
6.
Provide time-stamp on filename title when backup configuration file.
V
V
7.
Supports “Account Security” option on WEB GUI to encrypt admin / user account password and options to display user/AAA/SNMP credentials.
V
8.
Support auto configuration recovery on Nebula to prevent loss connection with NCC by misconfiguration.
V
9.
The year of Time Range page starts with current system time.
V
V
10.
Supports auto STP path cost which will determine path cost by the port's current link speed.
V
11.
Strengthen user security with the encryption of TACACS+ & Radius shared secret.
V
12.
Extend RADIUS server support range from IPv4 to IPv6.
V
13.
Enhance Auto PD recovery with a ping test button to verify connectivity.
V
14.
Enhance Guest VLAN to isolate broadcast packets between VLANs.
V
15.
Supports Flex link as a pair of Layer 2 interfaces for link redundancy.
V
16.
When switch is in CLV mode, there will be a reminder on VLAN configuration page.
V
17.
Add note on cable diagnostics to inform the operating limits for local web GUI.
V
18.
Support user uses “setup.zyxel.com” directly to access local web GUI.
V
V
19.
NCC discovery adds reminder to save configurations.
V
20.
Provide the Nebula password reminder on login page of web GUI.
V
21.
Unlock CLI to support full configuration in cloud mode.
V
22.
Nebula Switch supports SSH connection to access command line for advanced features.
V
V
23.
Nebula Switch supports IP source guard (IPSG) to prevent IP spoofing attacks.
V
24.
Support MAC authentication by cloud authentication on NCC.
V
25.
Support IGMP Report Proxy setting.
V
V
26.
Support Dynamic VLAN assignment through 802.1x authentication.
V
V
27.
The interval time of Loop errdisable recovery can be configured now.
V
V
28.
Support VLAN stacking (QinQ).
V
29.
[eITS #220801409] Extend the PD negotiation time limit on Legacy and Force-802.3AT mode to improve PoE compatibility.
V
V
Bug fix
No.
Bug fix
CLD
STD
1.
[eITS #221101865] Fixed IOP issue on the specific 1G-NIC will link on 10M when using auto-negotiation.
V
V
2.
[eITS #221100909] Switch will sometimes loose management after Nebula performs periodic operation to save configuration.
V
V
3.
[eITS #221100146] LACP configuration may leads switch not handle the 802.1x authentication.
V
V
4.
[eITS #221101240] Fix recording syslog may cause memory leak.
V
V
5.
[eITS #221101132] After restoring config via SFTP may cause fail due to syntax error.
V
V
Please refer to the Download Link for more details.
Zyxel Melen
