Vietnam Bike Parts Maker Pedals to Perfect Surveillance with Superfast Site-to-Site VPN
Zyxel_May
Zyxel_May Posts: 270 image  Zyxel Employee
First Comment Sixth Anniversary
edited April 2023 in Success Stories
SR SUNTOUR Cycling
“Network speed and stability improved significantly. Transmitting surveillance footage has gone from taking hours to minutes, and network management has become much easier, too.”
Chang Junhao
IT Manager, SR SUNTOUR Cycling
Summary
In 2020, SR SUNTOUR Cycling faced government requirements for continuous surveillance of its entire Binh Duong factory and an offsite warehouse. This necessitated a high-performance site-to-site VPN to transmit IP camera feeds from the warehouse to the factory for storage on NAS devices. However, its network was not unified and was cobbled together from various brands – including some consumer-grade products – leading to poor network performance and difficult management. Like many factories needing to connect more network and extra-low voltage (ELV) infrastructure like surveillance cameras, the company found it difficult to manage many connected devices from different companies. It turned to eSafe360, a system integrator specializing in ICT and ELV infrastructure. After evaluating the case, eSafe360 knew Zyxel’s solutions were up to the challenge. Zyxel’s USG FLEX 500 and USG FLEX 100 firewalls were installed in the factory and warehouse respectively, creating reliable, high-speed site-to-site VPN channels to transmit the video feeds in real time and lag-free. GS1350 switches were used to connect and power the IP cameras to ensure uninterrupted camera feeds. “Zyxel's solutions have allowed us to easily unify the site’s infrastructure and meet the customer's needs,” eSafe360 CTO Faraday Huang said.
Challenges
  • Ensure stable, lag-free data transmission of large amounts of surveillance footage between a factory and offsite warehouse
  • Fix the poor performance and cumbersome management caused by the use of communication and ELV system equipment made by different brands
Benefits
  • Enhanced work efficiency thanks to robust site-to-site connectivity
  • Higher network speeds and stronger stability supported by unified infrastructure
  • Worry-free network management due to responsive and professional technical support and planning
Products used
USG FLEX 100 UTM Firewall
USG FLEX 500 UTM Firewall
WAX510D WiFi 6 Access Points
GS1350 Series Smart Managed PoE Switch for Surveillance
More details
Download PDF for full story
