VPN Connection failing when using PPPoE, but direct connection is working
darksparks
darksparks Posts: 1 image  Freshman Member
edited April 2021 in Security
We're using a USG 20 connected to an Actiontec 1000 which is running in transparent bridge mode, using PPPoE.  As a regular firewall it's been working perfectly, but now we're trying to setup VPN connectivity.  When I connect a VPN client (computer) through a switch and into the USG20, the VPN connection is established and works perfectly.  However, when the VPN connection comes in through the Actiontec via PPPoE, it fails on the first ISAKMP packet with an ICMP "destination unreachable (port unreachable)" error.
Tried turning off the firewall portion, but still no connection.  I believe I have all the appropriate ports and protocols opened (proto 50, ports 500, 1701, 1723, 4500).
Any thoughts or suggestions would be appreciated!
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,482
    100 Answers 1000 Comments Friend Collector Ninth Anniversary
    image  Zyxel Employee
    edited September 2018
    Hi @darksparks
    I’d like to double check if this is your scenario and purpose:
    The VPN client needs to establish L2TP tunnel with USG which behind Actiontec 1000.
    USG20----------Actiontec 1000(PPPoE)----------Internet------Client
    If this is your scenario, you can reference to FAQ.
    Note: You have to setup the port forwarding on Actiontec 1000. (Forward 4500, 500 and 1701 to USG WAN address)
    By the way, what kind of USG20 you’re currently using? USG20 or USG20-VPN? Please note that the solution I mentioned above is working on the USG20-VPN
