NWA50AX slow wifi max 30Mbits/s
Today I noticed that my download speed on my laptop connected to an wifi access point on 5 GHz. I only get 30Mbits/s max download speed. My network consist of a:
USG FLEX 100
GS1920-24HP
NWA50AX 3x
AP connected with POE on the switch and uplink of Uplink: 1000M/Full
Can someone help me with the correct ap configuration
All AP are updated till the last firmware
Hello @nldutchie
As shown in your image, the connection type is 802.11a that utilizes radio frequencies in the 5 GHz range and has a maximum theoretical throughput of 54 Mbps, thus we suggest changing into 802.11ac/ax to optimize the wireless connection on your laptop.
Besides, the performance displayed in the Task Manager on your laptop is not an ideal tool to accurately measure internet speed. It only shows the current speed of data being uploaded and downloaded on your laptop, rather than the overall internet speed. Instead, we recommend using to determine the internet speed.
It's important to note that the Wi-Fi speed can be impacted by the distance between the AP and your laptop. The closer the laptop is to the AP, and the fewer obstacles there are in the way, the stronger the signal strength will be. The recommended signal is at least -65 dBm.
In case AP is managed by Nebula, please go to Site-wide > Clients > Client list tab and choose "Access points clients" on the drop-down list to check the Signal strength.
In addition, please provide your Nebula Org/Site name and enable Zyxel Technical Support for us to investigate further in case there are any configurations that need to be edited by following the instructions on the screenshot below.
Best Regards,
Nami
Nami
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
