Syslog Format for GS1920v2 Switches
Hello Community,
which syslog format do I have to configure on my remote syslog server (Graylog 5.1) so that the data from my Zyxel GS1920-8HPv2 arrives correctly?
CEF, RAW/Plaintext, simple Syslog and Subformat (AMQP, Kafka, TCP or UDP)
Tnaks forward
Chris
Hi @ChrisGer,
I did a local test with Graylog. I use syslog UDP format and successfully received the syslog from GS1920. You can reference the screenshots below.
And here's the Syslog server configuration guide for you to refer to.
Zyxel Melen0
Hi @ChrisGer,
Zyxel Melen0 -
Dear Melen,
thx for your test and feedback. after thorough research i found out that after activating the TLS connection to the webinferface the services / logging did not run. after a test without tls connection data from the switch arrived as hoped in the graylog monitoring.thanks for the help..... maybe there will be an official imput / template for graylog.
thanks and regards
ChrisGer0
- 241 Nebula Ideas
- 6.8K Security
- 758 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 321 Service & License
- 520 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
