Double NAT with two USG FLEX devices
But you want the traffic to go over the wifi to FLEX200?
No, the FLEX 200H should act as main router. Only some clients should be also reachable via double NAT through FLEX200.
The setup I gave is where you don't double NAT but if you need to do double NAT.
NAT
FLEX200
incoming WAN
external IP your WAN IP
internal IP 10.70.70.1
ports
NAT
FLEX200H
incoming interface of 10.70.70.0
external IP your 10.70.70.1
internal IP 10.50.10.50
ports
It also does not work with second NAT rule on 200H :/ I can see the request via traffic-capture on USG shared vlan but not on the vlan where the server (10.70.70.1) is in
Got it! Need "only" one NAT and one Policy Route with snat outgoing-interface at FLEX 200 on the right and a security policy on the left USG
- 244 Nebula Ideas
- 6.9K Security
- 801 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 329 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
