[Release Note] Small Business Access Point - V6.29 P2 firmware has been released
Zyxel_CSO
Zyxel_CSO Posts: 528 image  Zyxel Employee
5 Answers First Comment Friend Collector Ninth Anniversary
edited October 2023 in WirelessLAN New Release
Access Points Firmware Release Note V6.29 Patch 2
Date: October 20, 2023
Overview
This document provides firmware release information on Zyxel Access Points platforms, introduce new Access Points, new features and enhancements, bug fix, known issues and workarounds information for Release V6.29 Patch 2 C0.
Supported Platforms
NWA50AX V6.29(ABYW.2)C0
NWA55AXE V6.29(ABZL.2)C0
NWA90AX V6.29(ACCV.2)C0
New Features and Enhancements
1.Smart mesh support fixed band (NWA50AX, NWA55AXE and NWA90AX).
2. Standalone mode AP supports one-click automatic firmware upgrades.
3. Schedule reboot feature to solve the client IoP or connectivity issue.
4. CEF syslog enhancement.
Bug fix
Mode
Bug fix
Cloud
Managed
Standalone
1. [eITS: 221201027, 230100360, 230201226]
[Symptom] Nebula Client list can't show normally due to abnormal station signal collected from AP.
V
2. [eITS: 221200976, 221201233]
[Symptom] Repeater AP display offline status on Nebula after changing configuration due to AP state error.
V
3. [eITS: 230200225]
[Symptom] STA sometimes negotiation at 802.11a mode low speed.
V
V
4. [eITS: 230200215]
[Symptom] Device can't connect to the AP due to hostapd issue.
V
V
5. [eITS: 230200778, 230401471]
[Symptom] Device reboot by a kernel oops.
V
V
6. [eITS: 230200698]
[Symptom] 802.11kvr client capability cannot visible on Nebula Clients page.
V
7. [eITS: 230300082]
[Symptom] AP will reboot unexpected while admin login local GUI on cloud mode.
V
8. [eITS: 230300158]
[Symptom] Repeater AP will change to offline while performing renew DHCP.
V
9. [eITS: 230200619, 230500745, 230900281, 230900398]
[Symptom] TWT default enabled may cause some specific devices unexpected disconnection.
V
V
10. [eITS: 230201113, 230201390, 230400371, 230400770, 230800410, 230300635]
[Symptom] Repeater frequently disconnected from root AP.
V
11. [eITS: 230301784]
[Symptom] The portal page doesn't pop-up when SSID configured as Open + with Sign-on Nebula cloud authentication.
V
12. [eITS: 230301107, 230200997, 230500670, 230501673, 230600708, 230501510, 230601224, 230700617, 230801142]
[Symptom] Client deauthenticated by key handshake fail.
V
V
13. [eITS: 230301428]
[Symptom] Nebula managed message shows on standalone login web gui .
V
14. [eITS: 230401060, 230501350, 230501615, 230600356, 230600632, 230301106]
[Symptom] AP reboot by hardware watchdog.
V
V
15. [eITS: 230401304]
[Symptom] Nebula Client page shows abnormal signal value.
V
16. [eITS: 230401450]
[Symptom] The AP offline after updated firmware due to MTU size.
V
Known Issue
Mode
Known Issue
Cloud
Managed
Standalone
1. [eITS: 221001752]
[Symptom] The log cannot display expected wording while STA disconnected by SSID schedule.
V
2. [eITS: 231000132]
[Symptom] The information of password configuration path on Nebula is not correct showing in AP local login page.
V
3. [eITS: 230901349]
[Symptom] AP some configurations may disappear due to power off the device while device is applying or writing the configuration, and this is rare to happen.
V
V
4. [SPRID: 230905066]
[Symptom] Wireless client show rx rate 6M even it uses higher rate.
V
V
5. [SPRID: 230922270]
[Symptom] Wireless bridge repeater AP uplink port connect to other device may have LLDP issue.
V
V
6. [SPRID: 230922271]
[Symptom] Repeater AP should blink light blue LED while searching the available uplink AP.
V
V
7. [SPRID: 231019190]
[Symptom] Wizard can't pop out automatically when upgrade to this new version with default setting. Reset to default can solve this issue.
V
8. [Symptom] TWT is temporarily disabled due to a compatibility issue with specific Wi-Fi clients.
V
V
Limitation of Settings
N/A
Zyxel Nebula Support
