USG FLEX 50W Running 5.37 PPPoE Configuration
DeanH
DeanH Posts: 51
image  Ally Member
Hello Everyone,
On my USG FLEX 50W running 5.37 firmware, my ISP changed me from Ethernet connection to PPPoE connection all of a sudden. That is a long story that I won't go into detail on here. Needless to say I gave them an earful about how unhappy I was losing three days of Internet access because I was not informed of a change being made to my connection.
So, while working with them to get my configuration updated, I could only get the PPPoE active when I also had the Ethernet WAN interface enabled. This seems a bit redundant to me since they are both WAN connection types.
In my original static IP configuration, I had the Ethernet interface (CONFIGURATION > Network > Interface > Ethernet > wan) configured to use a fixed IP address, which was the static IP they assigned to me.
In the new configuration, I ended up having to set the Ethernet interface to "Get Automatically" and also configure the PPPoE interface (CONFIGURATION > Network > Interface > PPP > System Default > wan_ppp) to "Get Automatically" in order for the connection to work. So, rather than the static IP being held by the ZyXEL, they are passing it through to me.
When I initially disabled the Ethernet wan interface thinking they did not both need to be active, the PPPoE connection went down.
I would think the PPPoE interface alone should allow the connection to work without the Ethernet interface being active since they are both "wan" interfaces. Where am I missing the boat on this?
  • Zyxel_James
    Zyxel_James Posts: 841
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    image  Zyxel Employee
    Ethernet wan is the base interface of wan_ppp, so ethernet wan must be enabled.
    This concept also works with VLAN interface, the base interface LAN should be enabled when using VLAN.
  • Zyxel_James
  • DeanH
    DeanH Posts: 51
    image  Ally Member
    Thank you Zyxel_James.
    So, the ppp_wan is a sub-interface to Ethernet wan.
    I get it now, the tabs on the Interface page are in order of hierarchy from left to right. I missed that layout concept previously.
