Using ATP100 as Wireless AP Controller
Hello All,
I purchased a NWA210AX AP because I'm less and less happy with Unifi products. I want to use my ATP100 as a Wireless AP Controller. I'm having trouble finding the setup instructions to do this. The AP is getting an IP through DHCP from the ATP100, but I'm not seeing it any of the AP lists.
I am not using Nebula currently. If I need to add the ATP100 to Nebula, I'm open to doing that.
Thanks,
-John
Hi @ChipConnJohn,
NWA210AX supports the following operating modes only. It cannot be managed by ATP100 in on-premises mode.
- Nebula Cloud managed
- Standalone
Here is the list of Supported Managed AP for your reference.
Some of the guides suggest entering the default IP address manually in a browser, 192.168.1.2 from a device able to reach that subnet.
Have you tested that method or looked/sniffed for other subnets?
Hi @ChipConnJohn,
- Standalone
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
