Connecting zyxel switches guide?
Can anyone tell me what the best way to connect four zyxel switches are.
On one side of the building is a GS1920-24 and a GS1920-24HP
the other side is the same (4 in total, 2 on each side)
Lets say SW1 = GS1920-24, SW2 = GS1920-24HP, SW3 = GS1920-24, SW4 = GS1920-24HP
The person previous to me had it set up like this:
- SW1 connects to SW2 (1 foot fibre)
- SW1 connects to SW3 (fibre goes across the building)
- SW2 connects to SW4 (fibre goes across the building)
- SW4 connects to SW3 (1 foot fibre)
So each switch has two of its SFP fibre ports used. In total there are 8 ports used. There are 4 connections.
However this led to some kind of crazy broadcast loop or something happening (I think), the entire network went crazy, it even started causing laptops and PCs to lag and act funny, which is something I didnt know was possible.
As such I disconnected the fibre SFP link between SW1 and SW2. I also disconnected the link between SW2 and SW4. Now:
- SW1 connects to SW2 (1 foot ethernet)
This stopped the broadcast loop which was going crazy.
I am just wondering though, what is the correct way to connect switches together via fibre.
I remember seeing some diagram where it said you must connect for example SW1 SFP port 27 → SW2 SFP port 28, then SW1 port 28 → SW2 port 27. I think it said you cant connect SFP port 27 on one switch to SFP port 27 on the other? Does anyone have that diagram..
Hi @Lorcan,
According to the description, it seems like your network is a ring topology. In a ring topology, you have to set up RSTP to prevent loops.
Please reference this FAQ to configure RSTP:
Zyxel Melen0
Hi @Lorcan,
Zyxel Melen0
- 243 Nebula Ideas
- 6.9K Security
- 794 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
