dropping Port 4 (lan2)---wireless Lan
I have a USG60W which has been dropping Wifi. I was provided the recent firmware WK42 that was suppossed to resolve the issue. It worked for 27 days and is now dropping the port 4 (lan2) associated with the internal AP controller. (see screenshot below). This Unit has not worked properly since it was updated with fimware 4.25 and beyond. For security concerns, I cannot back date the firmware that far. I need a solution to this issue or I will be forced to remove this equipment and seek legal remedies.
Thanks for any assistance that you can provide-----Donald
FYI, I am an MCSE, Network certified, and I have been installing network equipment since the 90's. I have installed Cisco, Ascend, Lucent, And linksys equipment without these kind of issues. I have never
seen equipment as unreliable as this USG60W and the USG2100 which is also installed at this location. Neither device has worked properly since their initial installation which can be verified by the numerous open tickets associated with my user account.
Hi @Cobra,I also bridge the internal AP to lan2.P4 and P5 belongs to lan2.Connect one iPhone to SSID and ping 8.8.8.8 continuously.There is no abnormal port down/up symptom.The Ethernet link up/down should not affect the Wi-Fi connectionI connect one laptop to P4 and "manually" unplug and plug the ethernet cable to make P4 down and up.The wireless client (iPhone) is still connected without problem.Ping 8.8.8.8 continuously without any packet drop.Is P4 connected to any switch or device?Is lan2 assigned to P4 only?In Port Role setting, can you try to bind lan2 to ports other than P4 and monitor if other ports have the same issue?
First, your log file is different than mine. When the port went down in my log, the LAN2 interface was also disabled. Your log only shows the port going up and down without LAN2 being affected. There is an hp printer attached to port 4 so that Wifi users can print, but I am not sure why it would be dropping the connection?? The Wifi is still dropping, so I thought the port going down might have been related. Obviously, it is a separate issue. The problem that I am concerned about is the Wifi dropping and the SSID disappearing from the wireless clients. While this happens, users connected to a UAG2100 on the DMZ Port of the USG60W can still access the internet. This reveals that the USG60W is still routing traffic, but has no Wifi of its own. I updated the firmware again to WK43 posted in your dropbox. This firmware sent an update the the internal AP, so I will see what happens. What information do I need to log for you to troubleshoot the Wifi Issue??
Thanks------Donald0 -
Also, LAN 2 is connected to P4 only and the internal Access Point like you have shown above0
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
