Sys LED is flashing in red
Murat
Murat image  Freshman Member
Friend Collector
edited April 2021 in Security
Hi @all,
after power up my USG20 the Sys LED is flashing red.
I checked and searched in www but no answers.
Can somebody help me, why this happens?
I tryed to reset into factory setting already but this is not working so far.
  • Zyxel_Emily
    Zyxel_Emily image  Zyxel Employee
    Hi @Murat,
    We need console logs to identify if it is hardware or firmware issue.
    Is the SYS LED still red blinking even when the USG is finished booting up?
    Or the SYS LED is red blinking during the booting up process?
    Please connect the USG with console and enter the following commands when the device is booting up.
    If you're using TeraTerm, go to File > Log... > Option- select Append/Plain text/Timestamp.
    Then all console logs will be automatically saved in a file and send the file to us for analysis.
  • Schleppi451
    Schleppi451 image  Freshman Member
    Mine started doing the same thing a few days ago after the power flashed a couple of times. The SYS flashes green on power up, After 10 flashes of green, it starts flashing red. I tried resetting the unit and it still continues to do the same thing. I would like to get this unit operational again but had to purchase a USG20W-VPN to get the internet back up. I have a config file that I downloaded a while back from the USG20W. Is there a way to convert it or force an upload to the new -VPN unit?
  • Zyxel_Charlie
    Zyxel_Charlie image  Zyxel Employee
    @Schleppi451
    Regarding to the flashing issue, can you private message the console log which Zyxel_Emily mentioned for our analysis?
    Also, you can convert the configuration from USG20W to USG20W-VPN via this converter.
    Link:   https://convert.cloud.zyxel.com/
    Charlie
  • exaadmin
    exaadmin image  Freshman Member
    edited October 2019
    FYI, I had the same issue, SYS LED blinking red.
     I connected console cable, and displayed FAN error.
    Then I opened the cover and fix the fan manually.
    Therefore, try connect serial console cable speed 115200 and hopefully see the error.
  • Murat
    Friend Collector
    it is not possible to login via console, because the device is not reachable.
    I order a new one, so far so good.
    But interesting is to know what the other guys can do, if this happen?
