Assign WAN connections to specific LAN ports and WIFI in Zyxel VMG3625-T50B?
Can I use bridged and routing VDSL2 WAN connections simultaneously in Zyxel VMG3625-T50B modem/router?
I want to connect 2 LAN ports to bridged WAN and the rest LAN ports and the WIFI to routed WAN connection. Is this possible?
Yes it is in "Interface Grouping"
I have one PPPoE connection for the zyxel device at VLAN 835, one bridge connection for a second router at the same VLAN on LAN1, IPTV on VLAN 836 at LAN4 and another interface for VoIP at VLAN 837.
Notice that for each Interface Group you need to go at Home Networking and assign Default router Ip and DHCP enable/disable.
Well, RTFM is what I should've done a bit more before hitting the forums, but the answer was in the chapter 17 of the device's manual, Interface grouping.
I can create an interface group where I assign specific WAN interface to a certain group of LAN ports, including the WIFI.
Maybe someone with the same question finds this answer useful.
- Trokari1 -
I configured a second WAN in bridge mode to the LAN2 port, but it didn't work. I would appreciate any help with this.
Here is the configuration I loaded onto the ONT and the status of vlan on each uniport:
OLT1408A-C#
OLT1408A-C# sh remote ont ont-1-17----------------------+-------------------------------------------------------+----------------------------+-----------------
AID | Type SN Password Status Image Active SW Version Vendor/Version
ont-1-17 | Config 5A5958458CAD1FDD DEFAULT Active | 1 V541ACBB1F0 | ZYXE
| Actual 5A5958458CAD1FDD DEFAULT IS | 2 V V541ACBB1E0a06 | PMG5617T20B2
| Status : IS (1d 1h 19m 10s)
| Estimated distance : 86 m| OMCI GEM port : 16| Model name : N/A| Model ID : 0| Full bridge : disable| US FEC : disable| Alarm profile : DEFVAL| Anti MAC Spoofing : disable| Planned Version : ontImage| Description :
| Template Description :| Management IP Address : N/A+------------------------------------------------------------------------------------------------------
| Ethernet 1 : Link Up 1000M-full| Ethernet 2 : Link Down| Ethernet 3 : Link Up 1000M-full| Ethernet 4 : Link Up 1000M-full| POTS/VoIP 1 : On-hook Port not configured
| Wan 1 : Enable| Connection Type : IPoE| Status : Up| Nat : Enable| Service :| Default Wan : Enable| Vlan : 54| Priority : 0| MVLAN : 54| Auto get IP : Disable| IP address : 172.18.1.19
| IP Mask : 255.255.255.0
| Gateway : 172.18.1.1| Primary DNS : 200.29.238.10
| Secondary DNS : 8.8.8.8+------------------------------------------------------------------------------------------------------
| Wan 2 : Enable| Connection Type : Bridging| Status : Up| Nat : Disable| Service :| Vlan : 55| Priority : 0| MVLAN : 55| Auto get IP : Disable| Binding lan port : 2+------------------------------------------------------------------------------------------------------
| Wan 3 : Disable| Wan 4 : Disable| Wan 5 : Disable| Wan 6 : Disable| Wan 7 : Disable| Wan 8 : Disable+------------------------------------------------------------------------------------------------------
| Control Supported : WAN(full) LAN WiFi ACS ServiceControl DMZ UPnP Firewall
OLT1408A-C#
OLT1408A-C# sh remote ont ont-1-17 config----------------------+------------------------------------------------------------------------------------------------------
AID | Details
ont-1-17 | no inactive
| sn 5A5958458CAD1FDD
| password DEFAULT
| full-bridge disable
| description
| plan-version ontImage
| alarm-profile DEFVAL
| anti-mac-spoofing inactive
| bwgroup 1 usbwprofname 125M dsbwprofname 250M allocid 272
| ontServiceControl ftp enable WAN
| ontServiceControl ftp port 21
| ontServiceControl http enable WAN
| ontServiceControl http port 80
| ontServiceControl https enable WAN
| ontServiceControl https port 443
| ontServiceControl icmp enable ALL
| ontServiceControl snmp enable WAN
| ontServiceControl snmp port 161
| ontServiceControl ssh enable WAN
| ontServiceControl ssh port 22
| no ontServiceControl telnet enable| ontServiceControl telnet port 23
| ontLan 0
| ip static 192.168.100.1 255.255.255.0
| ip dhcp server 192.168.100.2 192.168.100.200
| exit
| ontWan 1
| vlan 54 priority 0 mvlan 54
| connection-type ipoe
| default
| ip static 172.18.1.19 255.255.255.0 172.18.1.1 200.29.238.10 8.8.8.8
| ip nat
| enable
| exit
| ontWan 2
| vlan 55 priority 0 mvlan 55
| connection-type bridge
| binding lan 2
| enable
| exit
| ontWifi 2.4g 1
| enable 1
| ssid Red_2.4GHZ
| password
| exit
| ontWifi 5g 1
| enable 1
| ssid Red_5GHZ
| password
| exit
uniport-1-17-2-1 | no inactive
| no pmenable
| queue tc 1 priority 0 weight 0 usbwprofname 125M dsbwprofname 350M dsoption olt bwsharegroupid 1
| vlan 54 gemport 272 ingprof DEFVAL aesencrypt disable
uniport-1-17-2-2 | no inactive
| no pmenable
| vlan 55 network 55 gemport 273 ingprof DEFVAL aesencrypt disable
OLT1408A-C#
OLT1408A-C# sh remote uniport uniport-1-17-2-1 vlan|AID | UNI-VID Status NNI-VID Tag PBit_Prof DSCP_to_PBIT Ing_Prof TC GemP AES_Ept SP MN
v|uniport-1-17-2-1 | 54 IS 54 tag inactive DEFVAL 1 272 disable of 1
-+---------------------+------------------------------------------------------------------------------------------------------OLT1408A-C#
OLT1408A-C# sh remote uniport uniport-1-17-2-2 vlan|AID | UNI-VID Status NNI-VID Tag PBit_Prof DSCP_to_PBIT Ing_Prof TC GemP AES_Ept SP MN
v|uniport-1-17-2-2 | 55 OOS-UO 55 tag inactive DEFVAL 1 273 disable of 1
Here is the configuration I loaded onto the ONT:
OLT1408A-C#
| Gateway : 172.18.1.1| Primary DNS : 1.1.1.1
OLT1408A-C#
AID | Details
| sn 5A5958458CAD1FDD
| password DEFAULT
| full-bridge disable
| description
| ontLan 0
| exit
| ontWan 1
| default
| ip nat
| enable
| exit
| ontWan 2
| binding lan 2
| enable
| exit
| ontWifi 2.4g 1
| enable 1
| ssid Red_2.4GHZ
| password
| exit
| ontWifi 5g 1
| enable 1
| ssid Red_5GHZ
| password
| exit
| no pmenable
| no pmenable
OLT1408A-C#
- 241 Nebula Ideas
- 6.8K Security
- 759 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 321 Service & License
- 520 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
