Resolving issues with wireless clients not receiving an IP address
Zyxel_Judy
This FAQ guides you through resolving issues related to clients not receiving an IP address.
For Default VLAN Configurations:
Verify DHCP server status: Ensure that the DHCP server is active and IP address pool is not overloaded.
For specific VLAN configurations for wireless clients:
- Confirm SSID VLAN ID: Verify that the SSID name is associated with the correct VLAN ID. Navigate to Access Point > Configure > SSID Advanced Settings, select the SSID, and edit the VLAN ID. The screen below shows if you want to set VLAN 10 for SSID.
2. Inspect switch port configuration: Check that the switch port to which the AP and gateway are connected is properly configured with the corresponding VLAN settings.
3. Check gateway VLAN interface: Ensure that the gateway is configured with the appropriate VLAN interface.
Zyxel_Judy
- 244 Nebula Ideas
- 6.9K Security
- 807 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
