VMG1312-B10D: Using SSID Subnet makes the AP unconnectable (i.e. DHCP does not give IPs)
stdedos
stdedos Posts: 2
edited March 2024 in Home Router
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    Hello @stdedos
    Welcome to the forum.
    I think that you might have found a bug, which will not get fixed on the VMG1312-B10D device because that went end of life by Zyxel in about November 2020.
    If the software is common to other Zyxel products, then it might get fixed.
    Kind regards,
    Tony
  • stdedos
    stdedos Posts: 2
    I … assume I cannot have the source to make my fix and sign my firmware to flash it, right? 😅
    "If possible", please let me know of "any future updates".
    Thank you for responding 😄
  • tonygibbs16
    Hello @stdedos
    You are welcome.
    If you want at your own risk to look at the source code, then you might be interested in looking this thread on the Kitz forum. https://forum.kitz.co.uk/index.php?topic=26923.0
    Obviously, you will be doing it at your own risk.
    Kind regards,
    Tony
