Small HomeLab network system
Hello!
I have an idea to use these devices for my HomeLab and manage it through NebulaFLex.
I already have MikroTik Chateau LTE router.
Switch GS1915-24EP - 1.pcs
+ Access point NWA50AX - 3.pcs
+ other RJ45 connections - 8pcs.
and some time later 6 security cameras might be added but for that my idea is to use separate PoE switch and NVR for that.
Do you have some other ideas for Zyxel switch/router setup?
Hi @Bunduks,
That sounds good. Just a reminder that the PoE power budget of GS1915-24EP is 130W. Since NWA50AX will cost 16W(maximum), purchasing another PoE switch for the security cameras is correct. Connecting all PDs to GS1915-24EP might reach the maximum power budget and make the device lose power.
Zyxel Melen0
- 244 Nebula Ideas
- 6.9K Security
- 807 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
