Using NWA1123-ACv2 to build a mesh
I have one NWA1123-ACv2 which I am using as a wifi access point. It is wired to my ISP router that provides the gateway to the internet.
I would like to add two new APs to extend wifi coverage in my house on the same SSID. I would like to reuse the ACv2 if possible.
I understand that the ACv2 is now replaced by the NWA1123ACV3. Can I purchase two of these, and link them with the ACv2 to form a wifi network with 3 APs and a single SSID? All APs would be hardwired back to the ISP router.
Thanks in advance.
Just to add, I am not currently using Nebula.
Hi @rich_b
Absolutely, you can purchase two NWA1123ACv2 units to extend your WiFi coverage. However, it's important to note that the NWA1123ACv2 has reached its End of Life (EOL) status. While it will continue to function, we advise considering our newer models like the NWA1123ACv3 or exploring our current offerings listed on Wireless | Zyxel Networks for better performance and ongoing support.
To ensure a seamless roaming environment, you can configure all APs with the same SSID and security options. For detailed instructions, please refer to this article:
For simplified management and monitoring, I highly recommend utilizing Nebula Cloud. With Nebula CC, you can centrally manage all your access points from a single platform, facilitating seamless configuration and maintenance across your network.
Kay
Hi Kay,
Thank you for your helpful reply. If I buy the newer mnodel NWA1123ACv3 can I use that alongside my one existing NWA1123ACv2 in the same network/SSID?
That's super, thank you!
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
