modem del1312-t10b problem doesn't work
after config internet lights turn to green and everything look good but when i connect to the modem with laptop or phone say you won't connect to internet i try wifi and cable but nothing work
i do everything update firmware and reset factory and config again everything normal but wont connect to the internet
  • Liba
    Liba Posts: 232
    First Comment First Answer Fourth Anniversary
    image  Master Member
    It is recommended that you contact your service provider or retailer for assistance.
