How to configure DHCP Relay on Nebula switch? (Pro Pack required)
Zyxel_Adam
The article guides how and where to configure DHCP Relay on the Nebula switch.
1. Navigate to Site-wide > Configure > Switches > IP & Routing > click Add button
2. Select a switch to fill in the necessary values, and click the Create button.
3. Check if the interface is well-created on NCC.
You can refer to the Device Function table to check if your switch supports DHCP Relay.
If you encounter any other issues, please help create a post here and tag @Zyxel_CSO, or create a ticket directly to reach us.
Adam
- 243 Nebula Ideas
- 6.8K Security
- 781 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
