How to configure DHCP Relay with option 82 on Nebula switch? (Pro Pack required)
Zyxel_Adam
Zyxel_Adam image  Zyxel Employee
Zyxel Certified Network Administrator - Nebula 25 Answers First Comment Friend Collector
The article guides how and where to configure DHCP Relay with option 82 on the Nebula switch.
1. Navigate to Site-wide > Configure > Switches > IP & Routing > click Add button
2. Select a switch to fill in the necessary values, and create an option 82 profile.
3. Name the profile and select the demanded ID and sub-option. Click Save & Back once finished.
4. Choose the created option 82 profile, and click the Update button.
5. Check if the interface is well-created with Option 82 on NCC.
You can refer to the Device Function table to check if your switch supports DHCP Relay.
If you encounter any other issues, please help create a post here and tag @Zyxel_CSO, or create a ticket directly to reach us.
Adam
