NWA130BE / BE11000 Power Supply
Hi @iridium,
Your guess is correct. The barrel jack dimensions are 5.5mm / 2.1mm. I'm sure how to describe the polarity of the jack, but I test this one and it can power on the NWA130BE.
Hope the information on the sticker helps.
Zyxel Melen2
Hi @iridium,
Zyxel Melen2 -
Do Zyxel sell needed power supply.
I bought the injector 30 watt but that occupies one of the ports. Not the best solution.
Hopefully Zyxel will answer in this thread.0 -
Hi @saltet,
I will help you to check with our local support. Could you help to provide your contact information? So our local support can contact you after checking. I will send you a private message for the request, please check your private message.
Zyxel Melen1 -
Yes, this helps a lot. Thank you!
As you can see from the sticker (the sign right of the "Efficiency Level: VI", top right of the FCC logo, it's following the more common polarity (center positive).
- 241 Nebula Ideas
- 6.8K Security
- 759 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 322 Service & License
- 521 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
