Smart mesh went bananas
my new smartmesh with three Nwe130 BE went offline this morning. The ap;s was installed and running a week a go and all went well. The root ap is connected to Zyxel 5101. The root ap is still green but the other two are red indicated.
Looking at the log something is happening. ?
Why is the smartmesh offline.
You Zyxel team have access to my account.
can you please give mean advice.
Hi @saltet,
After checking, we found that your APs crashed many times. That is why the smart mesh was offline.
In addition, since your APs have been upgraded to the latest firmware which fixes the crash issue, they are working well after 6/20. Please help to check if the issue happens again. Thanks in advance.
Zyxel Melen0
Hi @saltet,
Thanks for the privilege. We are checking on it and I will update you once I have further information.
Zyxel Melen0 -
Looking forward to hear from you.
my account is.
tomas.salzmann@telia.com
To solve my immediate problem I restarted the ap,s but the question is why did the ap go bananas.0 -
Hi @saltet,
Zyxel Melen0 -
Thanks a lot for your answer. That explain why my ap went off line.
since the upgrade -which I was unknown about - they have been working fine.
Best regards0
- 243 Nebula Ideas
- 6.8K Security
- 783 USG FLEX H Series
- 390 Security Ideas
- 88 Switch Ideas
- 58 Wireless Ideas
- 7.3K Consumer Product
- 325 Service & License
- 528 News and Release
- 102 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
