Difficulty connecting devices to wifi
We recently had broadband installed by a new ISP who provided a Zyxel EX3301-TO router. Most devices have connected to wifi and work seamlessly but my printer, although it connected briefly, will not stay connected and I cant connect an old Kindle device. Both worked fine on the old system, signal strengths are good. Is there likely to be an issue with the age of these items? (I would update the firmware but cant connect to wifi!)
you can try to set the 5G WIFI channel to the other channel, such as 48.
Then see if the Kindle can connection to the WIFI or not.
Maybe you can try to change the wifi security to WPA2 or WPA or OPEN and see.
Many thanks. Not long after posting this I got a call from the ISP help desk and they sorted it by changing some settings in my router, couldnt tell you what unfortunately
- 236 Nebula Ideas
- 6.8K Security
- 739 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
