Enhancing Fleet Connectivity and Management with 4G LTE-A Routers
Zyxel_May
Chung Shing Bus
Overview
With the increasing adoption of 4G LTE in the mobile broadband market, more
and more buses are equipped with mobile broadband routers to enhance
passenger internet experiences, operational efficiency, and fleet management.
Chung Shing Bus has stayed ahead of these trends and partnered with Zyxel
Networks to upgrade their network infrastructure with Nebula 4G LTE-A Indoor
Routers. These routers can be managed remotely and centrally via the cloud.
The installation allows passengers to enjoy high-speed internet on the bus, and
facilitates efficient network management and troubleshooting through the
cloud platform.
Challenges
Buses use mobile communication tech for efficient fleet management and
service quality. Yet, managing mobile routers presents several challenges.
Firstly, most mobile routers operate independently, lacking compatibility with
SNMP for centralized control. This makes it hard for system integrators to
create comprehensive management platforms, limiting their ability to provide
extended user support. Secondly, bus mobility creates a unique challenge as 4G
LTE connections may face disruptions due to base station switches or signal
interference, causing passengers to experience unstable connectivity. Lastly,
bus movement in urban and suburban areas often leads to 4G LTE signal
instability or insufficient coverage, especially in places like mountainous terrain
or tunnels where signal interruptions are common.
Solutions
To enhance mobile communication performance for Chung Shing Bus, Zyxel
Networks recommends the Nebula LTE3301-PLUS 4G LTE-A router, with
installation and maintenance managed by the system integrator, Yung Jih Cheng.
The router supports features Cat.6 4G LTE-A technology
with up to 300 Mbps data rates, alongside two external
upgradeable LTE/3G antennas, enabling high speed,
better coverage, and reduced signal interference.
Employing AC1200 2.4/5GHz dual-band concurrent WiFi,
ensuring stable and fast WiFi connection, enabling
sharing with up to 32 devices simultaneously, and
allowing passengers to surf the internet smoothly without
impacting fleet management.
Moreover, the router can be managed by the Nebula
cloud networking solution, which extends its services by
integrating Nebula wireless access points, switches, and
gateways. The cloud networking solution provides small
and medium-sized businesses or advanced users with
versatile deployment options as well as high-quality
network connectivity for business-critical digital
operations.
Results
By deploying the Nebula LTE3301-PLUS router, Chung Shing Bus has achieved a significant improvement in network connectivity. Additionally, with the Nebula cloud platform enabling real-time network management from anywhere, they can address network issues more efficiently. In case of equipment failures, automatic alerts ensure that IT personnel can promptly and easily assess on-site network conditions. The installation has improved operational efficiency for fleet management, allowing for real-time monitoring and management of the network on the bus, thereby optimizing bus operations.
- Improved operational efficiency for fleet management
- Streamlined Network Management facilitates efficient troubleshooting and network optimization
- Enhanced passenger experience with smooth internet access during their journeys
- Uninterrupted network connectivity through 4G LTE-A and Gigabit Ethernet dual-WAN connections
Products used
Nebula LTE3301-PLUS 4G LTE-A Indoor Router
More Information
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
