How To Reset Access Point? (Hardware Reset & Nebula Reset)
Zyxel_HsinBo
in Other Topics
Hardware Reset:
- Locate the Reset Button: Find the reset button on your access point.
- Press and Hold: Using a paperclip or similar tool, press and hold the reset button for about 10-15 seconds.
- Release the Button.
- Wait for Reboot: Allow the access point to reboot completely. This may take a few minutes.
Nebula Reset:
- Log in to Nebula Control Center (NCC): Access the Nebula via your web browser.
- Select the Access Point: Navigate to the sidebar
License & inventory » Devicestab and select the access point you want to reset. - Reset: Find the "
Remove from organization" option and click on it, when removed from Nebula organization, Nebula will send reset to default command to make device reset to default status. *Please ensure your device is online on Nebula when perform the device removal.
Note: A factory reset will erase all custom settings on your access point.
- 244 Nebula Ideas
- 6.9K Security
- 804 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 330 Service & License
- 537 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
