SSL Inspection not running well
PeterUK
PeterUK Posts: 4,791
image  Guru Member
USG FLEX 200H V1.21(ABWV.0)
Only some sites run well many others load slowly or not at all
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,169
    image  Zyxel Employee
    Hi @PeterUK,
    Could you provide the URL/link you test for us to check? We need the site run well and the load slowly one. Also, it would be helpful if you could share the loading time for comparison.
    Zyxel Melen
    image  Guru Member
    edited July 2024
    Hi Melen
    sites like (below) just don't load and times outs
    https://uk.yahoo.com/
    https://www.grc.com/intro.htm
    sites like (below) load ok but still the browser looks to be stuck to load something else for the site
    https://www.sslforfree.com/
  • Zyxel_Melen
    Hi @PeterUK,
    I did a simple local test and the websites "Yahoo UK" and "Home of Gibson Research" are able to load.
    Could you help to share these information for investigation?
    3. A video you access those websites, you mentioned above, with a timer.
    Thanks in advance.
    Zyxel Melen
    image  Guru Member
    edited July 2024
    The Server Signed Certificate Key Mode is the default ecdsa-rsa-2048
    I get a video done in VirtualBox
    Ok here is the video
    Also when I had a license non H Flex200 SSL Inspection worked fine
    image  Guru Member
    Other problems are the SSL Inspection is messing with the site code like scan.co.uk
  • Zyxel_Melen
    Hi @PeterUK,
    Could we schedule a remote session to address this issue? I will direct message you to arrange the timing.
    Zyxel Melen
