How can I ensure my AP receives enough power?
Zyxel_Bella
in Other Topics
To ensure your AP receives adequate power, you need to plug with Power Adapter or configure your PoE switch to provide the correct power budget and check the power standards it supports. Insufficient power may limited AP’s capability and reduce the performance or even disable the WiFi.
For each models specifications, refer to official website.
Steps to Configure Power Supply:
Verify that your PoE switch is capable of providing the required power for the AP.
Configure the switch to supply sufficient power.
- 244 Nebula Ideas
- 6.9K Security
- 802 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 329 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
