VLAN tags missing on monitor port
RambaZamba
RambaZamba Posts: 1 image  Freshman Member
I'm using a XGS1250-12 and set up port 12 as mirrored port. That port is part of 4 VLANs and doesn't untag them on ingress. I'm using port 3 as monitor port to connect a laptop running wireshark. Port 3 is not part of any VLAN. When I capture the network traffic, I do see all the packets I'm interested in, but the packets that are part of a VLAN header have their VLAN tag removed in the pcap. I've double-checked by capturing on the physical interface of the sending machine and the VLAN tag are part of that pcap. How do I have to set up port mirroring to see the packets exactly as they arrive/leave the mirrored port?
  • Zyxel_Nami
    Zyxel_Nami Posts: 659
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
    image  Zyxel Employee
    edited August 2024 Answer ✓
    Hi @RambaZamba
    To provide accurate assistance, please help clarify the following:
    1. VLAN - Egress Rule on Port 12: Please share the VLAN setting on Port 12. We would like to know if it is configured to tag VLANs or leave them untagged for egress packets. Knowing this will help us understand packet handling.
      1. Additionally, are VLAN tags missing on both ingress and egress packets on your monitor PC, not just on ingress packets?
    2. Wireshark Configuration: Ensure the VLAN ID column is enabled in Wireshark to verify the presence of VLAN tags on captured packets.
    3. Ensure the VLAN setting of NIC: image.png
    Thanks.
    Nami
    PeterUK Posts: 4,819
    image  Guru Member
    You can't you see them as untagged
  • Zyxel_Nami
    Hi @RambaZamba
    Thanks.
    Nami
