Zyxel USG Flex 100AX - problem with internet via Wi-Fi
I have a problem with accessing the internet via Wi-Fi connection to the Zyxel USG Flex 100AX device. Fresh installation. when I connect to it wirelessly, I constantly have no access to the internet even though the connection with network seems to be ok. Restarting the WiFi on my macbook temporarily solves the problem. I don't know what is causing it. I have the standard settings. If I set the address statically (manually) the connection is ok. When connected via LAN and with a DHCP address, everything is also OK.
network settings
band mode: 2.4G
security mode: wpa2
cipher type: AES
Expiration time: 7200s
Group key update counter: 30000
BANDWIDTH 802.11: 11bgn
Channel Width: 20MHz
Logs:
110 - 2024-08-16 16:12:52 - info - Wlan Station Info - STA left. MAC:[MAC ADRESS MACBOOK], AP:Built-in-AP, interface:wlan-1-1, SSID: name_of_ssid, Signal: -52dBm, Download/Upload:1248090
111 - 2024-08-16 16:12:52 - notice - Wireless LAN - Station: [MAC ADRESS MACBOOK] has disassoc by STA Logout on Channel: 6, SSID: name_of_ssid, 2.4GHz, Signal: -54dBm, Tx/Rx: 1480264/957470 Bytes. reason 8, Interface: wlan-1-1.
104 - 2024-08-16 16:12:54 - info - Wlan Station Info - STA connected. MAC:[some other mac address], AP:Built-in-AP, interface:wlan-1-1, SSID: name_of_ssid, Signal: -76dBm
105 - 2024-08-16 16:12:54 - info - Wlan Station Info - STA connected. MAC:[MAC ADRESS MACBOOK], AP:Built-in-AP, interface:wlan-1-1, SSID: name_of_ssid, Signal: -54dBm
106 - 2024-08-16 16:12:54 - info - DHCP - DHCP server assigned 172.16.85.192 to MacBook([MAC ADRESS MACBOOK])
107 - 2024-08-16 16:12:54 - info - DHCP - Requested 172.16.85.192 from MacBook([MAC ADRESS MACBOOK])
108 - 2024-08-16 16:12:54 - notice - Wireless LAN - Station: [some other mac address] has associated on Channel: 6, SSID: name_of_ssid, 2.4GHz, Signal: -78dBm. Interface: wlan-1-1.
109 - 2024-08-16 16:12:54 - notice - Wireless LAN - Station: [MAC ADRESS MACBOOK] has associated on Channel: 6, SSID: name_of_ssid, 2.4GHz, Signal: -54dBm. Interface: wlan-1-1.
101 - 2024-08-16 16:13:45 - info - Wlan Station Info - STA left. MAC:[MAC ADRESS MACBOOK], AP:Built-in-AP, interface:wlan-1-1, SSID: name_of_ssid, Signal: -49dBm, Download/Upload:244378/
102 - 2024-08-16 16:13:45 - notice - Wireless LAN - Station: [MAC ADRESS MACBOOK] has disassoc by STA Logout on Channel: 6, SSID: name_of_ssid, 2.4GHz, Signal: -54dBm, Tx/Rx: 342016/258264 Bytes. reason 8, Interface: wlan-1-1.
97 - 2024-08-16 16:13:48 - info - Wlan Station Info - STA connected. MAC:[MAC ADRESS MACBOOK], AP:Built-in-AP, interface:wlan-1-1, SSID: name_of_ssid, Signal: -55dBm
98 - 2024-08-16 16:13:48 - info - DHCP - DHCP server assigned 172.16.85.192 to MacBook([MAC ADRESS MACBOOK]) [count=3]
99 - 2024-08-16 16:13:48 - info - DHCP - Requested 172.16.85.192 from MacBook([MAC ADRESS MACBOOK]) [count=3]
100 - 2024-08-16 16:13:48 - notice - Wireless LAN - Station: [MAC ADRESS MACBOOK] has associated on Channel: 6, SSID: name_of_ssid, 2.4GHz, Signal: -55dBm. Interface: wlan-1-1.
96 - 2024-08-16 16:13:59 - info - DHCP - DHCP server offered 172.16.85.192 to MacBook([MAC ADRESS MACBOOK]) [count=3]
94 - 2024-08-16 16:14:09 - info - DHCP - DHCP server assigned 172.16.85.192 to MacBook([MAC ADRESS MACBOOK])
95 - 2024-08-16 16:14:09 - info - DHCP - Requested 172.16.85.192 from MacBook([MAC ADRESS MACBOOK])
92 - 2024-08-16 16:15:35 - info - Wlan Station Info - STA left. MAC:[MAC ADRESS MACBOOK], AP:Built-in-AP, interface:wlan-1-1, SSID: name_of_ssid, Signal: -51dBm, Download/Upload:101625/
93 - 2024-08-16 16:15:35 - notice - Wireless LAN - Station: [MAC ADRESS MACBOOK] has disassoc by STA Logout on Channel: 6, SSID: name_of_ssid, 2.4GHz, Signal: -55dBm, Tx/Rx: 128761/120573 Bytes. reason 8, Interface: wlan-1-1.
88 - 2024-08-16 16:15:37 - info - DHCP - DHCP server assigned 172.16.85.192 to MacBook([MAC ADRESS MACBOOK]) [count=3]
89 - 2024-08-16 16:15:37 - info - DHCP - Requested 172.16.85.192 from MacBook([MAC ADRESS MACBOOK]) [count=3]
90 - 2024-08-16 16:15:37 - info - Wlan Station Info - STA connected. MAC:[MAC ADRESS MACBOOK], AP:Built-in-AP, interface:wlan-1-1, SSID: name_of_ssid, Signal: -55dBm
91 - 2024-08-16 16:15:37 - notice - Wireless LAN - Station: [MAC ADRESS MACBOOK] has associated on Channel: 6, SSID: name_of_ssid, 2.4GHz, Signal: -55dBm. Interface: wlan-1-1.
87 - 2024-08-16 16:15:46 - info - DHCP - DHCP server offered 172.16.85.192 to MacBook([MAC ADRESS MACBOOK]) [count=2]
86 - 2024-08-16 16:15:58 - info - DHCP - DHCP server offered 172.16.85.192 to MacBook([MAC ADRESS MACBOOK]) [count=2]
84 - 2024-08-16 16:16:15 - info - DHCP - DHCP server offered 172.16.85.192 to MacBook([MAC ADRESS MACBOOK])
81 - 2024-08-16 16:17:12 - notice - Wireless LAN - Station: [MAC ADRESS MACBOOK] has associated on Channel: 6, SSID: name_of_ssid, 2.4GHz, Signal: -55dBm. Interface: wlan-1-1.
Hi @mlik,
From the logs seems like your device left the SSID. Is this done by you?
May I know if you did the ping test when the issue happened? If yes, what's the result?
Zyxel Melen0
- 241 Nebula Ideas
- 6.8K Security
- 758 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 321 Service & License
- 520 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
