Crafting Reliable and Secure Networks for Cross-store Operational Efficiency
Zyxel_May
Zyxel_May Posts: 270 image  Zyxel Employee
First Comment Sixth Anniversary
edited September 2024 in Success Stories
Le Blé d’Or
Overview
Le Blé d’Or operates 18 stores throughout Taiwan. As part of their digital transformation, introducing more advanced technology and ensuring smooth network connectivity has become essential. However, these stores do not have on-site IT personnel; all IT equipment is managed by headquarters’ IT staff. The company sought assistance from Zyxel Networks to ensure stable and fast network transmission across all stores. After deploying the new network, they could enjoy a high-performance and secure network as well as efficient network management and troubleshooting by leveraging the Nebula cloud networking solution.
Challenges
With stores spread all over Taiwan and no IT staff on-site, the headquarters’ IT team had to handle all the equipment remotely. Any mistake in setting up network equipment could disrupt the stores’ internet connection, causing service interruptions or communication problems between locations. On top of that, dealing with firewalls required specialized skills. To tackle the challenges, the IT team at headquarters needed quick access to a technical support team that could help resolve any issues right away
Solutions
Le Blé d’Or upgraded its network infrastructure with Zyxel Networks’ solutions to achieve digital transformation and enhance network management.
The NWA210AX WiFi 6 access point provides stable, high-speed wireless transmission and supports multi-gigabit speeds with high power efficiency.
Supporting PoE+ power standard, NWA210AX delivers optimal performance without complex rewiring, ensuring a smooth network upgrade.
The NWA90AX Pro WiFi 6 access point offers AX3000 WiFi speeds and a 2.5G uplink Ethernet port, delivering ultra-fast WiFi 6 speeds to support multiple devices and high-performance applications.
The USG FLEX 200 firewall incorporates advanced cybersecurity technology and offers flexible licensing options to ensure comprehensive network protection.
Its subscription plans are easily expandable, allowing for enhanced security measures. Additionally, the GS1350 series surveillance switch is specifically designed for surveillance systems, equipped with robust hardware and software features to meet the power needs of high-speed surveillance cameras.
Results
These products address Le Blé d’Or challenges by ensuring stable network connectivity, high-speed wireless access, comprehensive cybersecurity, and reliable power supply for surveillance systems.
With the Nebula cloud networking solution, Le Blé d’Or can instantly identify network issues and ensure comprehensive network security. Nebula allows direct inquiries about configuration issues with prompt responses, eliminating the need for phone communication or searching for support.
The solution enables efficient network management and troubleshooting without on-site IT personnel, facilitating the smooth achievement of digital transformation goals.
  • Improved network performance guarantees stable,high-speed wireless transmission across all 18 stores and high-performance surveillance system
  • Comprehensive cybersecurity features ensure robust network protection
  • Efficient network management with simplified and responsive technical support
Products used
NWA210AX WiFi 6 Access Point
NWA90AX WiFi 6 Access Point
GS1350 Series Surveillance Switch
USG FLEX 200 Firewall
More Information
Download PDF for full story
