Secondary IP addresses on interface problem
USG FLEX 200H V1.21(ABWV.0)ITS-24WK35-0813-240800592
Howto add secondary IP address on interface? — Zyxel Community
There is no primary so I have
/ vrf "main" interface ethernet "ge4" ipv4 address "192.168.255.235/26"
/ vrf "main" interface ethernet "ge4" ipv4 address "192.168.255.253/26"
/ vrf "main" interface ethernet "ge4" ipv4 address "192.168.255.248/26"
With a VPN for interface Ge4 to nailed up to 192.168.255.243 my USG40 only that end is expecting from 192.168.255.235 which I think was the primary only the FLEX200H randomly picks how it sends VPN connection out from and so the VPN fails not much I can do so I had the other end nailed up to 192.168.255.235 to make it work for now.
So there need to be a primary.
Hi @PeterUK,
From your screenshot, the My Address part is still using the interface rather than fixing the virtual interface IP address. Please reference the below.
Zyxel Melen0
Hi @PeterUK,
Since the virtual interface cannot set orders now, could you help to change the VPN setting > Network > My address from the interface to a fixed IP address? This should avoid randomly picking the IP address.
Zyxel Melen0 -
It is fixed
The problem is when nailed up on FLEX200H side the source IP of ge4 LAN can pick from
The other end is expecting say 192.168.255.235 but the FLEX200H uses 192.168.255.248 as source when nailedup and so their is a mismatch.
Hi @PeterUK,
Zyxel Melen0
- 244 Nebula Ideas
- 6.9K Security
- 801 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 329 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
