Wall or ceiling mount for AP?
I'm asking this here because I have not found any information on this topic anywhere.
I have an NWA130BE and want to connect it with a single RJ45 cable via PoE, but would like to know if there are any recommendations for how to mount it for the most efficient covering.
Hi @FlashBytes
For the best performance and signal coverage with your access point, we recommend ceiling mounting. This positioning typically provides the most effective signal range and distribution, as it allows the signal to travel more freely and cover a larger area.
You can find additional guidance on the ideal placement for access points in this post:
Kay
Hi @FlashBytes
Kay
- 234 Nebula Ideas
- 6.7K Security
- 713 USG FLEX H Series
- 370 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 314 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
