AP problem
I have 2 Zyxel switches and 3 nwa90ax APs in my system. I had a system that was working properly until yesterday. There was 1 SSID defined in the system. I added 2 more. Today, one of the APs started not working properly. When I removed it and moved it to another place, it works properly. But it does not work in its original place. I changed the entry point on the switch, but the same situation still occurs. How can I solve this? The blue LED is constantly flashing in its place. The green is not on.
Hi @Erkan,
Do you mean you did a cross test that change the AP to connect to the same switch port and the issue reproduced?
Could you describe more details of the symptom with us to clarify this issue?
Zyxel Melen0
- 234 Nebula Ideas
- 6.7K Security
- 719 USG FLEX H Series
- 371 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 315 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
