Zyxel AX7501-B1 disable led blinking
aschmidch
aschmidch Posts: 2 image  Freshman Member
Is it possible to disable the led blinking on a Zyxel AX7501-B1.
I found the command:
ZySH> sys ledblinking off
But that didn't work. Any ideas?
  • Rob7777777
    Rob7777777 Posts: 5 image  Freshman Member
    First Answer First Comment
    Update to the latest firmware V5.17(ABPC.5)C0
    Click on the LED button ON/OFF.
  • Rob7777777
  • aschmidch
    I upgraded to this firmware, but have overseen the menu change for the led.
    Thanks for pointing me to it, it works.
