Switch problem - SYS
Good afternoon, I have a new Zyxel switch that, when started, keeps the SYS flashing green non-stop and does nothing else. It does not turn on any port. The firmware cannot be updated because it does not detect any connections. How should I proceed?The model is GS1920-8HP. Greetings
Hi @Amat
To help us understand the issue with your GS1920-8HP switch, could you please provide the following information?
- Power Supply: Is the switch receiving sufficient power? The required input for the GS1920-8HPv2 is as follows:
- Factory Reset: Have you tried performing a factory reset on the switch? You can do this by holding the RESTORE button for more than 7 seconds. After resetting, please check if the switch returns to normal.
- Video Recording: Could you please share a video of the switch's symptoms via private message? This would help us in diagnosing the issue more accurately.
Kay
Good morning Kay,
Steps 1 and 2 that you mentioned have been done and it doesn't work either. Sending a video with a private message with the problem.
Hi @Amat
Thank you for sharing the details and the video.
Based on this information, it seems there may be a hardware issue with your switch. We recommend reaching out to your reseller or local support team to submit an RMA:
- For the EMEA region, follow the guidelines to check the device warranty and submit an RMA.
Submit an EMEA RMA request - For the US region, use the link below to submit an RMA request.
Submit a US RMA request
Kay
0 - For the EMEA region, follow the guidelines to check the device warranty and submit an RMA.
Good morning Kay,
Thank you very much for your response and management. I have already opened an RMA with the incident to request a change of equipment.
Regards,
- 244 Nebula Ideas
- 6.9K Security
- 801 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 329 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
