Why can't my switches connect using a DAC cable?
Zyxel_Chris
Zyxel XGS/XMG/XS series switches support SFP+ and DAC-10G on fiber ports. To maintain network stability, the port's media type must match the cable in use.
If the media type and cable are mismatched, the ports may fail to link, repeatedly link up and down, or experience high CRC error counts.
This guide explains how to adjust the port's media type, based on firmware version v4.80:
Configuration Path:
Navigate to Port > Port Setup, locate the connecting port, and change its Media Type to match the cable.
Default Setting:
The default media type is set to SFP+.
- 244 Nebula Ideas
- 6.9K Security
- 801 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 329 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
