Flash standard firmware on to AX7501
Hi
I have a AX7501-B1-CH01V1F from my provider. I'll switch my provider end of january and he said i can keep the router. The thing is, it's flashed with a special software from my provider. It would be too bad to just throw it away. Is there any option to flash the standard firmware from Zyxel to the device?
Regards
You can try to deactivate the firmwarecheck via ssh using tool putty for example . If it is changed you can update the other version in the web gui . Here is a link :
https://community.zyxel.com/en/discussion/11497/xmg3927-b50a-firmware-version
- 241 Nebula Ideas
- 6.8K Security
- 759 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 321 Service & License
- 520 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
