How to control my AP locally and not via the web portal?
Zyxel_JoyLee
Zyxel_JoyLee Posts: 184 image  Zyxel Employee
Friend Collector First Anniversary
Connect to the AP: Ensure that your computer or device is connected to the same network as the Zyxel AP. You can connect via Ethernet cable or Wi-Fi.
Determine the AP's IP Address: You'll need to know the IP address of the Zyxel AP to access its GUI. You can usually find this information in your network settings or by checking your router's connected devices list.
Open a Web Browser: Launch a web browser such as Chrome, Firefox, or Edge on your computer or device.
Enter the IP Address: In the address bar of your web browser, type in the IP address of the Zyxel AP and press Enter. This should bring up the login page for the AP's GUI.
Login Credentials: You'll be prompted to enter login credentials. By default, the username is "admin" and the password is "1234".
