WAC500H with problems
Good afternoon, community!
After performing a manual reset (using the button on the device), the WAC500H no longer works. When I connect it to a power adapter or a PoE cable, the device turns on, the LED blinks between green and amber, and I get a link light on the connected Ethernet port.
After about 3 minutes of blinking, all lights turn off, including the one on the connected Ethernet port. If I disconnect and reconnect the power, the cycle starts again.
I have already tested with two different power adapters and PoE.
Do you have any recommendations to bring this device back to life?
Melen , thank you very much for your help. I was able to access it using the ZON utility, update the firmware, and reset it. However, after booting, the device turns off all the lights again. When I try to adopt it in Nebula, it says that the device is already registered. But I have deleted the device from Nebula, and it still says the same. Can you help me with this?
- 245 Nebula Ideas
- 6.9K Security
- 812 USG FLEX H Series
- 393 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 543 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 125 Security Highlight
