Extension cable for ANT2105 antenna
I have an outdoor mesh WiFi network composed of several ZYXEL WAX655E (AX5400) units, but I find them too visible in our garden. Are there antenna extension cables available for the ANT2105 antenna that would allow me to hide the ZYXEL WAX655E access points in a hidden spot without affecting their functionality?
I noticed that the ANT2105 antenna uses an N-type connector. There is any extension cables or adapters to relocate the ANT2105 antennas one or two meters away from the WAX655E? Alternatively, are there suitable "low-loss" cables or extensions available on the market that I could use without significantly degrading the signal? If yes, what would you recommend?
Thanks very much,
Carlo
Hi @Carlo1969,
ANT2105 has a compatible cable: LMR 400-N. Please reference the below URLs for more details.
https://www.zyxel.com/global/en/products/wireless/ant2105-antenna-and-cable/photos#:~:text=LMR%20400%2DN,N%2Dplug%20Cable
https://www.zyxel.com/global/en/products/wireless/ant2105-antenna-and-cable/specifications
Zyxel Melen0 -
Thanks! Where can I buy it online or in Europe (France or Italy)?
Hi @Carlo1969,
Please contact our distributors for more details:
Itally:
France:
Also, you can send your contact information to me via private message, I will ask local sales to contact you.
Zyxel Melen0 -
Good morning. After this discussion here I bought, as you suggested, 2 extensions LMR 400-N here:
https://store.zyxel.com/91-005-075004g.htmlOn this page is written that these extension cables are compatible with my external wifi WAX655E but the problem is that your cables are identical on both sides (both female) so it's completely impossible to plug them between my external access point WAX665E and its existing antenna ANT2105. To do that I should have a male / female cable and not a female / female cable. What is the problem? How can I do that?
The reference number of the extension cables I received is 91-005-075004G. Thanks for help
Any idea?
Hi @Carlo1969,
I apologize for the delayed reply since I was checking some details.
First, LMR 400-N's connectors are plug (male), so it can plug into WAX665E. However, the existing antenna ANT2105 is a special spec for WAX665E, a plug(male) that can plug into WAX665E without the LMR 400-N. Therefore, you will need a jack(female) antenna to connect the LMR 400-N.
Since you mentioned your LMR 400-N is jack(female) on both side, could you help to take a photo so we can check with our product team?
Zyxel Melen0 -
Thanks for answer. This is the cable LMR 400-N you suggested me to buy which is male both side (not female, sorry). How can I connect it to extend the existing ANT2105 antenna which is also male ? It's impossible
Hi @Carlo1969
Thank you for your update. I sincerely apologize for providing you with inaccurate information. I have consulted with our team, and we recommend that you purchase an "N Jack to N Jack Adapter" instead of an additional N Jack antenna. The "N Jack to N Jack Adapter" is capable of connecting the LMR 400 and ANT2105 antennas. Furthermore, we will update our website to include this notice. Thank you for your valuable input.
Zyxel Melen0 -
Ok thanks
LMR 400 is also available in 3 meter or only 1 meter and 9 meters?
Normally we should have at least 6 meters but I cannot find it anywhere
Are you still selling it?
- 234 Nebula Ideas
- 6.7K Security
- 722 USG FLEX H Series
- 371 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 316 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
