Will firmware upgrades reset or overwrite switch passwords?
Zyxel_Judy
Issue details:
After upgrading my switch's firmware, I can no longer log into the WebUI. My previous password is not being accepted, and even the default password (1234) doesn't work. Does the firmware upgrade process overwrite or reset switch passwords?
Answer:
As per our specifications, upgrading the firmware will not reset or overwrite the password. We recommend you check the password carefully and try again.
If you are still unable to login with the password you remember, please reset the switch (press the RESET button for more than 6 seconds) to login with the default password: 1234.
Zyxel_Judy
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
