NWA1123ACv3 Energy bursts accross 2.4MHz channel 1 and 11
Hello Support,
Please can you tell me if this is normal behaviour?
The image shows a scan from the 2.400GHz to 2.433GHz, channel 1, taken from my TinySA Ultra+. I've isolated it to the wireless router and bursts change as I change channels. I get the same high energy bursts on channel 11. It is not continuous but changes through out the day. Usually, I observe a consistent diagonal dot pattern.
When I switch the router off, the burst disappear. What is more interesting is that when I leave it turned-on, connected to the switch, but disconnected from the firewall, the bursts also stop as if externally triggered.
I tried installing the latest firmware but the high energy bursts continue? Please advise…
Current set-up: Netgate 1100 → Zyxel GS1900-10HP → NWA1123ACv3
Output from Tiny SA Ultra+ 2.400GHz to 2.433GHz (1) and 2.441GHz to 2.483GHz (11):
SOURCES:
Hi @ASGR,
Before we check this issue, may I know some details first?
- What makes you want to check it with the Tiny SA Ultra+? Is there any issue trigger you to check?
- "I've isolated it to the wireless router and bursts change as I change channels" What do you mean change channels? The Wi-Fi radio channel? Or?
Thanks for sharing the information.
Zyxel Melen0
- 431 Beta Program
- 2.6K Nebula
- 168 Nebula Ideas
- 6K Security
- 368 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 266 Service & License
- 409 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
