Why Sign-in method in SSID advanced settings can not be enabled or changed?
Zyxel_JoyLee
Zyxel_JoyLee Posts: 167 image  Zyxel Employee
Friend Collector First Anniversary
edited June 2025 in SSID
The Sign-method feature cannot be enabled or modified because some models, such as the NWA50AX and NWA55AXE, do not support the Sign-in function。 Below it is a portion of the device function table as an example for a reference。
You also can go to Help >> Support tools >> Device function table ( Zyxel Nebula - Device function table ) to know all the function of Zyxel products.
