m pro mesh with ex5601-to and wx3401-bo
Have a router ex5601, bougt 4 wx3401-bo, all products support mpro mesh.
It is working plugging cable between 5601 and 3401, then it shows up in app as a satelite under 5601 and connection is fine. But when I remove cable to use wifi connection, it still shows up in app as a wireless satelite, but when clients connect to them it does not work, and the middle light is not lit.
Trying to add the 3401 by wifi in the app, only count down 2 minutes and no connection.
Turning of mpro mesh setting for 5601, and using a 3401 as controller works, then I can add the next with wifi in app with no problem. But then I get another wifi network in the house.
Is it possible to fix this? It is working by cable between 5601 and 3401 so why not wifi?
use WPS button to pairt bewteen 5601 and 3401 by pressing first WPS on 5601 and then press WPS on 3401. these will let these two devices connecting in wireless mode.
- 237 Nebula Ideas
- 6.8K Security
- 745 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
