Get a hard drop with my wifi clients between points (NWA130BE)
ericshufro
I get a hard drop with my wifi clients between points (NWA130BE). Any idea? Also, I am finding the range to not be very good (residential use). I think the signal is full near the AP, and then unusable about 40 feet away. One regular house wall in between. Is that typical?
Hi @ericshufro ,
The issue is that your WiFi clients aren't roaming properly between APs, causing disconnections when you move around.
Solution requirements:
- Configure all APs with the same SSID name and security method
- Deploy APs with 15-20% overlapping coverage between adjacent units
Reference guide for proper AP deployment:
Zyxel_Judy
Hi @ericshufro ,
Zyxel_Judy
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
