Why does the remote VPN with AD authentication fail on the USG Flex H model?
Zyxel_Jeff
Zyxel_Jeff Posts: 1,408
100 Answers 500 Comments Friend Collector Sixth Anniversary
image  Zyxel Employee
edited June 2025 in VPN
Question :
The user may encounter an issue where they can obtain the VPN provisioning file from the firewall using AD authentication, but cannot establish an IKEv2 VPN connection with AD authentication.
The user can get the VPN provisioning file from the firewall successfully.
However, the IKEv2 VPN connection cannot be established, and the event log will show "generating IKE_AUTH response 4 [EAP/FAIL]" and "RADUIS authentication of ‘AD account’ failed.
Answer :
The possible reason is that the firewall has not been joined to the AD domain. Once the firewall successfully joins the AD domain, the IKEv2 VPN can be established normally.
Join Domain
Join Domain successfully
The VPN connection can be established.
