[Troubleshooting] PDs Not Powering Up or Unstable Connection with PoE Switch
Zyxel_Tina
Zyxel_Tina Posts: 1,087
Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 250 Answers 1000 Comments
image  Zyxel Employee
If your powered device (e.g., an IP camera) fails to power on or frequently disconnects when connected to a Zyxel PoE switch, please follow this troubleshooting checklist:
1. Port Cross-Testing
  • Swap the port to other PoE ports for cross testing.
2. Check Cable Material
  • Ensure you are using CAT5e or CAT6 copper cables.
3. Firmware Update
  • Make sure your Zyxel switch and powered devices (PDs) are updated to the latest firmware.
4. PoE settings (only support on PoE switch models)
  • Verify your Power-Up mode configuration. This setting determines which power mode is provided to the PD. Please note that power-up modes may vary depending on the switch model.
Zyxel Tina
