What to do if WiFi clients do not receive a DHCP IP address?
Zyxel_HsinBo
Zyxel_HsinBo Posts: 532
Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - WLAN
image  Zyxel Employee
If a client connects to WiFi but does not receive an IP address, the issue is usually related to DHCP availability, VLAN configuration, or AP uplink settings. Follow these quick checks:
1. Check DHCP Server
  • Make sure the DHCP server is available and reachable.
  • Verify the IP address pool is not full.
2. Check SSID & VLAN Settings
  • Ensure the SSID is mapped to the correct VLAN.
  • Verify switch ports allow the VLAN between the AP, switch, and gateway.
  • Make sure the DHCP server has a scope for this VLAN.
3. Check AP Uplink
  • Confirm the AP is can reach the client VLAN's gateway.
  • Ensure the switch port is correctly configured (access/trunk).
4. Check the Client Device
  • Ensure the device is set to obtain an IP automatically (DHCP).
  • Forget and reconnect the SSID, or toggle WiFi off/on.
