How to fix configuration and filesystem issues on the EOL NWA1123ACv2
Zyxel_HsinBo
Zyxel_HsinBo Posts: 525 image  Zyxel Employee
Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - WLAN
The NWA1123ACv2 is not adopting Nebula configuration, and logs show high filesystem usage - "/db filesystem usage reaches 93%".
How to Resolve:
  1. Factory Reset the AP
    • Press and hold the reset button until the device restarts.
    • After reboot, check if Nebula configuration is adopted correctly.
*The message “/db filesystem usage reaches 93%” usually does not affect service unless the device is under heavy load or misconfigured.
Note:
NWA1123ACv2 has been end-of-life since December 2022, so firmware updates and full support are no longer available.
